Asv cab won’t lift
Rkrkopp
New to the forum. I purchased a used 2016
Vermeer ft100 forestry mulcher that I found out while trying to find a Manuel that ASV made it for Vermeer. I blew a hydraulic line and can’t get the cab lifted to access the lines. I’ve pulled all 4 bolts in the floor. I’ve talked to the local dealer and ASV support. They both say it should lift with a little help.
I’ve even tried to lift it with another skidsteer.
It lifts about one inch and seems to get stuck.
Has anyone experienced this?
Thanks. Rob.
From my experience with asv 60 rt30 rt60 example..... yes you could remove the cab entirely (never did) but my real question is why ?
You say to replace a broken hydraulic line, I've changed soo many lines and never remover the cab before
I always used metal ramps that are rated 5 ton, drive up backwards, remove the skid plates and find your hose.
Unless...... maybe...... Its a hose going to your hydraulic tank itself
Hope this helps and I believe this is one reason why you cannot remove the cab, hydraulic line going to tank and possibly wiring harness if you didn't unplug including throttle cable ect
Thanks. I will try some ramps to get it off the ground. I have dropped the belly pans to see.
Still would like to lift the cab for better access.
Thanks. Rob
My original post I did not specify it’s a ASV 120 the can should tilt back. Don’t want to remove it.
My original post I did not specify it's a ASV 120 the can should tilt back. Don't want to remove it.
I am not familiar with that machine but, I have had cabs that would not raise on other machines.
The problems that I have found are:
Something caught in the hinge point i.e. rocks, tools etc.
I had one machine that someone had spun the auxiliary hose while tightening it and the steel bend in the hose end was catching the cab.
I’ve seen throttle levers that were bent over enough to stop the cab from raising.
Since you tried to lift it with another machine I would assume that it is not just a bad strut but I could see, under some weird circumstance, where the strut could be locking up and not allowing the cab to rise.
All I can suggest is to lift the cab as far as you can and then carefully inspect everything around it. If you can have a helper lift the cab up and down while you move around it, you may be able to hear where it is catching.
Hope this helps.
I've seen throttle levers that were bent over enough to stop the cab from raising.
Hope this helps.
Thanks anything helps. We have done what you said. I can lift the front of the cab about an inch. And barely see between the cab and the fuel tank it looks like the bottom of the cab is getting stuck on the fuel tank that raps all the way around the machine. But when I tried to lift the cab with another skidsteer it would have broke the plastic fuel tank if that was all that was blocking it. My machine is two hours away so I can only work on it weekends. Thanks. Rob
Hope this helps.
I would agree with all that was said above. I noticed in one video of these that before they tilted the cab they cleaned all the junk away from the hinge points. I doubt that there is a safety catch but this has to be something out of place to only get it an inch from the frame You need more eyes that can see when the lift is attempted. On top, at hinge points, inside if possible. Then maybe from under the unit if the skid pan is off. Good Luck with this.
have you tried looking at the parts schematic's on things about the cab, maybe then you may find something that is holding it down, something that your just not able to see with everything assembled, just a thought ? as I know its some times easy to not be able to see things, yet there in place behind hoses or plates or what ever??
so using the parts schematic's can some times show you what your unable to see!
I'm not really familiar with that specific model but I have a Terex/ASV PT100 and have been pretty much rebuilding it from the ground up (don't ask 😂).
First, mine has a lot more than 4 bolts. I have at least 6, maybe 8 that go around the skirt surrounding the cab.
2nd, you have to have the loader up and locked on mine or it will hit and stop like you described.
3rd, door has to be shut or it will hit the loader arms on mine. (I couldn't understand why mine wouldn't go up one day right after I had just lowered it. 😂 I was alone too so getting tired trying until I figured it out.
I don't see any Vemeer listed but if it really is just an ASV, Track loader parts has free manuals. I like their site and order a lot of parts from them. Here's a link to the manuals for a regular ASV PT-100 Forestry
https://www.trackloaderparts.com/on...forestry/asv-pt100-forestry-free-manuals.html
Thanks. I do have the arms up and locked out. It appears like the cab is getting stuck under the fuel tank in the front. When I get back down to my machine I think I’ll pull the fuel tank so I can get a better look.
This is probably off base. I have an SR80 ASV.
Once I tried to open the cab up and was really struggling. . . until I realized I pulled out the WRONG two bolts!
RE-check to make sure, look harder. Sounds stupid. . . but ?!$#
Old thread but I'll follow exactly in Rkrkopp's footsteps I guess: 'new to forum, I just got a 2012 Terex PT70 (same cab as the OP I think) that I can't lift.
First I went to remove the 2 cab retention bolts at the outside corners of the cab - and the bolts aren't there; I found the empty welded-on-nuts where they would go. I budged the cab up a little and planed to come back to it (I thought I budged-lifted it slightly...I currently can't budge it at all so maybe I was mistaken).
It doesn't help there are exactly zero (useful) pictures in the operator's, service, and parts manuals or on the entirety of the internet it seems on exactly how these cabs lift (does the footpan come with it? I assume not but someone above is talking about removing 6 bolts / that sounds like the footpan). One of the footpan bolts is also missing.
The cab is either seriously caught on something as discussed above, or the gas lift-ing strut is shot, or both. Tomorrow I'll try the chains-to-the-top-and-gradually-pull-back-on-it-with-my-tractor trick.
These ASV machines have a clever design, but I hadn't realized the diesel tank on these literally wraps around the cab...interesting. I' don't think I've ever been surrounded by diesel before.
So, in my case the gas struts must be shot, and just that, because the cab lifted easily with chains-tractor. The cab bolts are right where you'd expect (mine were missing), and the cab lifts like you'd expect.
The brace is tough to work with because hoses smash it against the cab.
The wood bracing in the picture, besides being extra protection, was used so I could safely get the cab brace engaged.
End up figuring it out? Currently stuck in the same situation, cab lifts up about an inch and then gets stuck under fuel tank. Any help is appreciated. Thanks
Figured it out. Pulling the wrong bolts. Have to pull the 4 above it that are hidden
