AGT MX-CRT23
MikeTexas
2025 model. I ran it for 30 minutes then parked it and wouldn’t start after that
It’s new. I checked the 2 20 fuses and they’re good but I’m not getting any spark from either spark plug
Any help would be greatly appreciated
I know nothing about that machine but I would suggest to check all the safety points to see if you left something on that needs to be off when starting. check the manual.
Hopefully there’s someone out that’s worked on one of them
with gas engines there is a kill wire that goes from the ground and to the key switch and to the coil . take off the engine shroud off and disconnect the smallish wire on the coil ( they should be linked together if two coils) and retest for spark. Have you disconnected the low oil monitor as a test to see if it is defective? that will kill spark also if bad or oil level to low.
I’ve already disconnected the low oil sensor
Pulling the kill wires from the ignition coils was what I was thinking. I’ll try that and see what happens
Thanks for the advice
Figured it out. Was a wire on the kill button
button
