AC question
johndeerefarmer
Seeing if these pressures and temp readings are right for a 35P mini X
Ambient 96 degree in the shade, 60% humidity
Machine has auto idle off, wide open throttle.
Fan and cool are at max
Low side: 28 psi
High side: 260 psi
Vent temp is 49 degrees.
With machine shut off pressures are 44psi and 240psi.
Occasionally the compressor will kick off then right back on.
Anybody know what the high pressure cutoff is?
