909 backhoe weight
here is basic info on it showing it at 1425 lbs with a 12 inch bucket, so, pending what bucket you have may change things, and there are also a few versions of this backhoe, so, some other models may be more or less possibly
here is a link to spec's as well as link to the manual, (509 B ) and I added spec's below as well added them below
]Bradco 509 Backhoe Specs[
Tractor Compatibility
3-Point hitch ............. Category 1/2
Tractor rated power, Hp (kW) ............. 40-80 (30-60)
Hydraulic flow, gpm (l/min) ............. 9-12 (32.5-43.2)
System relief valve setting, psi (bar) ............. 2500 (172)
Dimensions and Weight
Transport height (with boom fully retracted), in (mm) ............. 93 (2355)
Transport width (with stabilizers up), in (mm) ............. 60 (1518)
Ground clearance, in (mm) ............. 11 (278)
Overall length, in (mm) ............. 91 (2303)
Boom pivot height, in (mm) ............. 16 (405)
Operating weight (with 12-in bucket), lbs (kg) ............. 1425 (648)
Operational Data
Digging depth (maximum), in (mm) ............. 116 (2935)
Digging depth (2 foot flat), in (mm) ............. 115 (2910)
Digging depth (8 foot flat), in (mm) ............. 99 (2505)
Overall operating height (fully raised), in (mm) ............. 154 (3896)
Loading height, in (mm) ............. 82 (2075)
Loading reach, in (mm) ............. 50 (1265)
Reach from swing post, in (mm) ............. 153 (3871)
Bucket rotation, degrees ............. 180
Swing arc, degrees ............. 180
Straight wall digging depth, in (mm) ............. 87 (2200)
Stabilizer spread operating position, in (mm) ............. 95 (2405)
Stabilizer down below grade, in (mm) ............. 16 (405)
Digging force (bucket cylinder), lbs (kg) ............. 5676 (2580)
Digging force (dipper cylinder), lbs (kg) ............. 2754 (1252)
Hydraulic Cylinders
Bucket Cylinder (Bore/Stroke), in (mm) ............. 3 (76) / 18.4 (467)
Dipper Cylinder (Bore/Stroke), in (mm) ............. 3 (76) / 21.4 (542)
Boom Cylinder (Bore/Stroke), in (mm) ............. 2.75 (70) / 24.8 (628)
Swing Cylinder (Bore/Stroke), in (mm) ............. 2.5 (63) / 7.65 (195)
Stabilizer Cylinder (Bore/Stroke), in (mm) ............. 2.5 (63) / 16.4 (415)
Backhoe Buckets
Bucket Width, in (mm) ............. 12 (305)
Rated Capacity, cu.ft (m3) ............. 1.25 (0.036)
Weight, lbs (kg) ............. 125 (57)
Number of teeth ............. 3
Bucket Width, in (mm) ............. 16 (405)
Rated Capacity, cu.ft (m3) ............. 1.72 (0.049)
Weight, lbs (kg) ............. 148 (67.3)
Number of teeth ............. 4
Bucket Width, in (mm) ............. 18 (455)
Rated Capacity, cu.ft (m3) ............. 1.95 (0.056)
Weight, lbs (kg) ............. 156 (71)
Bucket Width, in (mm) ............. 20 (506)
Rated Capacity, cu.ft (m3) ............. 2.81 (0.08)
Weight, lbs (kg) ............. 165 (75)
Bucket Width, in (mm) ............. 24 (608)
Rated Capacity, cu.ft (m3) ............. 2.65 (0.076)
Weight, lbs (kg) ............. 180 (82)
Bucket Width, in (mm) ............. 34 (860)
Rated Capacity, cu.ft (m3) ............. 3.82 (0.11)
Weight, lbs (kg) ............. 238 (108)
Number of teeth ............. 7
Bucket Width, in (mm) ............. 36 (910)
Rated Capacity, cu.ft (m3) ............. 4.05 (0.12)
Weight, lbs (kg) ............. 246 (112)
Bucket Width, in (mm) ............. 38 (960)
Rated Capacity, cu.ft (m3) ............. 4.28 (0.13)
Weight, lbs (kg) ............. 255 (116)
