Can you get oil on them? Or is it the actual spools tight? Sometimes you get corrosion in the caps with the centering spring.well, i finally hooked it up today. everything functions as it should. some of the pistons had rust on them, i just sanded them smooth. the swing piston was a bitch because it had some rust on the back and i couldnt see it. the controls are touchy to say the least. what kind of grease could i put on the block to keep the controls smooth? they are a little stiff.
Good to hear you got it running again.
