ReTonkulousgarage
- Joined
- May 1, 2026
- Messages
- 7
I am building a house. A friends dad gave me an 863 to use for the duration of the build. He had loaned to an abuser for a couple of years. Zero maintenance. It is free for me to use, but I have been fixing many issues. I have more hours working on it than using it. Now I need to get the pad done sooner than planned, so I will rent a dozer to finish it. But I am not the guy who gives a borrowed tool back not working.
SN 514414477 1995 year? Manual foot controls. "NO JOY STICKS" Local Bobcat does not want to touch it.
I have service and parts manuals.
8 hoses replaced.
3 cylinders rebuilt.
Fuel tank pickup converted to steel. (required removal of the power unit on this model.)
Hour meter fixed.
Fuel gauge fixed.
Temp gauge fixed.
New seat.
All BICS sensors cleaned and checked.
New tires.
I have 100 hours on it since picking it up.
The new issue is the interlock will randomly engage. I can not replicate by doing a specified function. Scooping, dumping, traveling in both directions, happens with any of them. It has been getting worse as I work through the issue. Now it locks within 5 minutes of starting the unit.
Control panel shows traction failed. 3 flashing lights. "Coil circuit shorted to ground".
Done so far. Checked the traction solenoid for correct operation. Was OK. Checked power to the solenoid and the ground. OK.
Replaced solenoid. No change.
Pulled all of the harness apart that I could access. Checked all of the plugs. Continuity tested all BICS wires end to end and to ground. They all check OK. I have checked all of the plug pins, cleaned and made sure contact is happening. Cleaned the fuse holder and contacts. Switched the brake relay with the starter relay. No change.
I pulled the traction solenoid and clamped the lock pin up. Bolted the solenoid to the side with one bolt. I can travel freely, but the failure light will come on as I watch it.
While using the unit locked out, it worked fine for about 30 minutes. Then the control valve failed and boom/tilt locked. Shows 3 blinking lights also. "Valve output circuit shorted to battery voltage".
Looking for advise.
8 hoses replaced.
Hour meter fixed.
Fuel gauge fixed.
Temp gauge fixed.
New seat.
New tires.
Looking for advise.
