At start-up all lights on the BICS light up for a second and go out but when I lower the seat-bar the seat-bar lights up with no other lights on except the power light. When I go to operate; the traction locks and the lift/tilt locks-up. The traction override allows me to only move the bobcat. I took the seat sensor apart and cleaned, moved the magnet about without any luck. Can a bad seat sensor cause both the traction and control valve lights not to work? I have checked the brake circuit, fuses and relay, also took the BICS out and inspected the board and checked the harness for shorts all connections looked clean. I used ohms on all the circuits and found nothing obvious. I’m thinking its ether a bad BICS or a Bad seat sensor. Any suggestions will be appreciated.
