kilohertz
- Joined
- Feb 12, 2012
- Messages
- 124
As the title states, I am at point in my machine restoration where I could remove the BOSS/BICS and go with ??
The machine is new to me and I have got the engine and drives working great, I still have no hydraulics, as after pouring over the older version schematics, have figured out I am missing a major harness for the AUX hydraulics, which also seems to have the power to the lock solenoids in it. The machine had started to be stripped for parts, so already missing are the intrument panels, both sides, this AUX harness, most of the seat/bar sensors are buggared and I am dealing with a cab wiring harness that has been hacked off right at the key panel...
Yesterday I figured out the wires in the cab to get it started and the alternator charging again, I have old school gauges and key panel coming from an 843 and will wire those in...but to get the hydraulics working....I am now thinking to remove the BOSS system. The BOSS box is still under the cab, and it's main harness is there, and engine harness and harness out the boom arm to bucket area is there...but I am missing one harness with an 8 pin square plug from the engine harness, and one harness from under the cab by the big circular connector, 6 pin I think, and also there is a controller missing, has 2 plugs, something to do with AUX hydraulics on the sticks???
Anyway, my goal is to get the hydraulics working with the least amount of PITA in the future. I will need at least the main AUX hyrdaulics working as I have an auger and may be looking at a landscape rake.
I am an electronics guy as well as mechanic so wiring is not a problem...just want to know the best way to acheive my goals. Would appreciate some input from anyone who has replaced/removed BOSS, and what did you have to do to keep all hydraulics working. I don't much care about all the safety shutoff crap for the engine etc. My old 720 doesn't have a computer to tell me something is wrong, I can hear it, or the machine will tell me thru noises or feel. I will have temp and oil pressure gauge, can put in a light for hydraulic charge pressure, and whatever else is critical.
Your thoughts?
cheers
Your thoughts?
cheers
