my 853 has a major water leak , after this winter i put the loader in my garage to do the oil change, filters ect. after checking all the fluids i discovered the radiator being low on fluid. I added a gallon and then another , this is not common for my machine , needless to say the water ended up directly in my oil pan almost as fast as i put it in. I sure that this is not good, now im wondering if its a head gasket , cracked block/cracked head or a cyl. sleeve. not sure how to approach the problem , should i pull the engine just to make it easier to work on ? any help would be great. and how much of a pain is it to pull the engine? does the operator cab have to come off? the machine has 3700 hrs
