cwjohndeere
- Joined
- Mar 3, 2015
- Messages
- 15
Good evening everyone, just thought I would share some information to possibly save someone some trouble down the road. The auxillary hydraulic solenoids in the "Apitech" valve have been leaking oil from the cartridge itself meaning I'm guessing that the stem of the cartridges were worn through. I had to change one of them when I first purchased the machine since it was leaking so bad and I ordered it through the bobcat dealer to the tune of around $300.00, recently the other cartridge began leaking worse so I did some talking with the local Parker distributor (Parker bought Apitech in the 90's) and he was able to find me a replacement part for $130.00, less than half the cost from bobcat. The part number is VS1320-0111. The only difference is the electrical connector, the machine uses a two pin metri-pack connector which you cannot get from parker, this solenoid comes with a weatherpack connector. I just cut the connectors off of both the harness and the solenoid and crimped on a deutsch connector I would imagine though that you could use whatever kind of connector you wanted though or even a butt connector if you wanted. My machine is an 853 with the BOSS controller I'm not sure if other versions of the machine will be different so this probably will not apply to all 853's. Hmm I was going to post some pictures but I cant figure out how.
