DUDE PULL RAD SEND TO LOCAL SHOP.have repaired 35 bucks, replace stat install new coolant, before putting (NEW )rad cap on a coulpe of quick checks? 1 check for presence of combustion gas in cooling sys. (napa block test kit consits of bottle of fluid (blue) that will turn green or yellow if combustion gas prenset. instuuctions included. 2 put rad press tester on fill neck. if climbs my concerns being the 7753 eng never even got warm so lets back up . issue being overheat; rad leaking? forget all that. get rad fixed check cooling belt and angle drive for proper operation,this is probally issue. fan dont work eng overheats weak link goes, fan drive spring loaded tension. should snap back, easy fix new arm spring etc while you are there change out the 90 w in angle drive often neglected? stupid check i use at full throttle should blow hat off head at louvers. if not fan aint working.
