773 glow plug fuse,
300winchester
Located a fuse box back by engine compartment, does not specify which fuse if for Glow Plugs, the fuse box is NOT in cab below seat !! Is there another fuse box location under cab ? There are 8 fuses in the box in engine compartment, 2 accessories, what do the accessories control ? No voltage to Glow plugs, >? need help Thanks in advance and Happy Holidays to all
Older machines did have fuses in the engine bay.
The accessories could be for starter, glow plugs, park brake etc.
I'd pull them one at a time and see if any are blown.
What series is the 773? It could be there is only a relay for the glow plugs. It will be behind the cover located under the seat. Here is a video that shows the panel layout in a G series machine if you need a reference. I had a traction lock issue but it was related to the relays not seating well into the back of the panel but the video has a good image of the location of the glow plug relay. Bobcat 15-02 Traction Lock Error Video
