SpaceCase614
- Joined
- Jan 11, 2013
- Messages
- 22
I used to get the 15-03 error code (Traction Lock Pull Coil Error Off) and what I found was that it was always blowing the 30A traction fuse. Didn't happen all that often, twice in about 6 months. Now in the past 4 days I've popped it 4 times, twice today, and the code this last time changed from 15-03 to 15-02 (Traction Lock Pull Coil Error On). What is the difference between these two codes? Now when I plug in a fuse I hear the clunk then the fuse immediately pops. Even with the key off. So right now the bobcat is stuck in my yard and I can't move it. Is it the pull coil that is bad? I popped the cab open and can't see anything obvious electrically that would cause a short or anything. I don't know where the coil is though to check it out more thoroughly. There is the 30A fuse and a relay both labeled Traction. The 15-03 always fixed easily, when it popped earlier today I replaced the fuse and was good for another couple hours. I just got done setting my hottub back on my deck when it popped again and threw the 15-02 and that's when it blew the fuse as soon as I put it in. Help!
