763 won't start
Oukachiru
Was out in the field and went to restart bobcat. Panel turns on but on full key turn there is a pop sound and the panel dies. Panel won't cone back on unless battery is disconnected and reconnected.
Replaced battery, same issue.
Popping sound is coming from somewhere in engine compartment I think, but can't turn key and look at same time.
Any thoughts on what to check next?
Possibly the "switch power" relay, number 15. Swap that relay with another like the headlight relay. Its simple to do. The fuse box is between your legs a few inches down from the seat. There are two 9/16 bolts holding the cover on.
