theboogers
- Joined
- May 1, 2008
- Messages
- 13
i got a older 773 wiith 400 hours on it from a farmer i know. real clean. anyhow i got a old, clean with new hoses, but working d100 case backhoe attachment. took me a long time to get the hydraulics to attach. the quick disconnect would not go on. i tried to turn key to left to drain off pressure but it still wouldn't work. i had to break the coupling at the qd to relieve the pressure then attach. took forever to learn how to bypass hand controls on bobcat to allow working of attachment. backhoe worked real nice, but it has a lot of sticks for the movement. not as nice as kubota unit i used with just 2 sticks. it will take a little getting used to. my question is even at a idle the backhoe works real fast. is there a way to slow down the hydraulics a little to adjust the backhoe movements? do i have to put a relief valve somewhere to really let pressure off of system on 763 to allow attachment to pop on? is there a relay not opening releasing the pressure enough? i waited about 10 15 seconds for the pressure to release without any luck. thanks,
