What model of 763? Does it have a panel at upper left with the seat bar light, or is there a BICS panel behind the operator's right elbow where the seat bar LED is located? The seat bar (aka lap bar, aka carnival bar) has a switch at the left side pivot point (in my very limited experience). It's a Hall-effect switch, which uses a rotating magnet near an enclosed solid-state switch (electronic, no moving parts, mounted to the ROPS cage). As the bar is lowered, the magnet rotates into the correct position to actuate the switch. So you can detach them from the bar and play with the two pieces while watching the light, assuming the wiring is intact. There are a couple of nibs protruding from one of the pieces that fit into a slot in the frame so the magnet and switch are aligned properly. That's worth checking also.
---Bobbie-G
