753C aux hydro flow
Unicam
can someone tell me which line the fluid comes out? like top or bottom, i need to plumb a one way valve and want to get it in the right line because taking it back apart if i need to reverse it would be a pain. thank you
One answer is whichever coupling you want it to. By default, if you pull the trigger on the right hand lever, the fluid should come out of the top coupling. However, you can reverse the direction of the flow by using your thumb to control the paddle switch on the top of the same lever. If the thumb paddle is flipped to the left side, the hydraulic pressure flow will then come out of the bottom coupling and return thru the top.
