753 Fuel delivery problem
Calvins753
On a full tank of fuel my 753 runs fine. After running for 10 minutes it starts sucking air and dies. If I top off the tank and remove the air it runs fine. I cannot find where the air is coming from.
It sounds like you have either a cracked or broken pickup tube in the fuel tank. As long as the break or crack is submerged it works like normal but starves for fuel when the level drops.
It's a pretty common problem, and fortunately one of the least expensive to fix.
flyerdan, I’ll check that out it’s the only thing I haven’t checked. Thanks for the info!!
