mikeprince
- Joined
- Aug 26, 2012
- Messages
- 10
I just bought a 753 that looks really clean, no leaks, tight wheel bearings and chain, starts right up, etc. 1600 hours. Previous owner claims it was a landscapers. I didn't get any maintenance records though. Sometimes when I start it I can't travel forwards unless backing up a little first. It feels like BICS is working - all lights come on and I can hear the solenoid click. When I try to drive forward you can hear the engine bog down and virtually no forward progress. If I back up just a bit and then try to go forward there are no problems. After the initial backup it drives normally. The chain case oil looks good and the previous owner claims a "1500 hour factory service" was done. I haven't pulled the chain case cover off to drain and check the drain filters yet. Is this normal? Anything else I should try?
