743B Lights Upgrades
Atilathehun99
Been looking w/out success for replacement LED lamps for the 743B. Also thinking about adding a front light bar. Where can I tie in to power that? Likewise I need a tie in for a cig socket to plug in a flashing warning light to stick on the roof for when I'm working areas where traffic is present.
I did all of the above to my 722 by running wiring to the instrument panel. The 743B doesn't have the same all inclusive panel.
Thanks in advance for all comments/suggestions/advice.
go off the hot side of your keyswitch add a fuse and switches on vacant areas to your accessories. if you want those switches controlled by the key use the assories postition of switch.
