743 Vickers pump oil leak
oldbikerguy
Hi I recently pulled the pump out of my 743 as it appeared to be leaking a fair bit of oil(a different thread). I see some oil leaking from the joint between the vane pump and main body. Would anyone know what the bolts should be torqued to? If you have the proper torque setting for all the bolts not just for the bolts connecting the vane pump I would appreciate it. I want to make sure all bolt are tightened to the right specification. Thanks, Joe
