Have a 743 that temp gauge was not working since I bought it. Gauge and sensor were both bad, wire was good. Put in new gauge and sensor. Gauge shows running hot after just a few minutes of running, antifreeze level is full and reservoir at line, radiator is not building up pressure, radiator water temp is running 120F using thermometer, checked temp at thermostat housing and at bottom radiator fitting with laser, just a few degrees apart at 116F. So two questions, is it not building pressure due to cap and is the new sensor or gauge possibly bad?
