743 stuck aux hydro
Hey OM do you have a blow apart view of the aux hydro valve would like to see what I am getting into thank you
No real tips, the innards are very simple. The part you are messing with is just a rod with one seal on each end of the valve block to hold the oil in.
Remove the rear cap and use a punch to try and tap the bolt that holds the spring to the rear of the spool.
If it doesn't move, you will need to pull the valve out. If it's that rusted, you will need to do some serious work to it.
Thanks Tazza I will give it a try but am going to try to get a few other bugs out first does not leak and not ready to open that can yet
