743 smoking on start up
Thanks Tazza and Farmshop! Well some good news today, I received the thermostat and so was able to put it in and test her out. I was lazy and did not repeat the compression test or check for valve clearances. Well, after priming she fired right up. There was some white smoke but not a huge amount. There seems to be some blow by but not a huge amount (although I don't know what is a lot). The first cylinder temp is still low, but not as low (maybe about 185 when the other cylinders are 200). Upon revving up, there is now no hesitation, no knocking and black smoke, just a bit of white smoke after hitting the throttle, then goes away (mostly, there are still some fumes). In contrast, when I got the machine 2 weeks ago, it was very, very hard to start, then poured black smoke (probably masked the white smoke), then white smoke, and would knock and pour black smoke when going past 1/2 throttle. So in summary, although the engine doesn't seem new and has some signs of wear, I'm thinking it might be ok to run it like it is (the engine at least!). Well, I didn't mention the rockers with uneven wear, but will save for another day. I did bugger up two of the injectors (a brass washer on the injector for cylinder 1, and the thing that has the return hoses for the injector on cylinder 2), and will need to address.
During replacement of the thermostat (or more accurately, adding the previously non-existent thermostat!), I flushed the coolant, and upon removing the coolant hose to the overflow tank, discovered that the copper nipple where that hose attaches to the radiator (just below the radiator cap) had broken off! So once the coolant heats up, it pushes against the cap and instead of going down the overflow hose in to the overflow reservoir, pours down into the engine compartment and on top of the battery! Just another sign of the lack of attention from the previous owner, or a pessimist might even think deception from the previous seller (and my lack of careful evaluation before purchasing). I attempted a repair, using a propane torch, flux and solder, and it seemed to work, we'll see if it holds up (it seems to be holding after 10 minutes of driving).
Tazza, my compression gauge is so cheap, I can't be sure that the 420 reading was accurate. But will hope it is!
Farmshop, thanks, I'll keep an eye on the coolant levels, and if they drop, will start stressing about how to do a leak down test...!
I'll try her out tomorrow, and if good, will just focus on fixing the injector seals, and then call the engine fixed enough for me, for now. I would like to express my sincere thanks to Farmshop, Tazza, and this forum for the help on this problem in particular, and general helpful suggestions in this forum over the years. It's really helpful for unknowledgeable guys like me...!
I'm wondering if it was sitting for some time and the injectors are freeing up? Possibly add some injecotr cleaner to the tank and give it a bit more of a run to get it nice and warm, good time to change the oil too. Glad it is running far better than it was. The knocking sound, if it has gone away, sounds like it may have been a sticky injector?
If it is starting well, i wouldn't doubt the pressure reading, even with a cheap gauge. As long as they are all the same or very close.
Hopefully your soldering repair will hold, it doesn't take much abuse to break this over flow neck off.
This forum is a great source of knowledge, lots of people happy to give up their time to do what they can to help.
A pint of automatic transmission fluid in the fuel works well for lubing the fuel system.
#1 - IF an injector is dirty a can of Sea Foam or some Lucas injector cleaner would be a good place to start. Put some in it and run it hard for a 1/2 hour or more and see what happens. #2 - IF you think there's air in the fuel lines, block the wheels, start it up, idle it down, then using TWO wrenches, crack the fuel lines at the injectors one at a time - starting with the one farthest away from the injector pump. Leave each injector line loose (cracked) for about 3 seconds or so. PUT A RAG NEAR YOUR WORK, SO IT WILL CATCH MOST OF THE FUEL. If you still have black smoke coming from it the injectors are probably junk. You can buy NEW ones on Ebay for about $25 each.................but buy NEW ones and get oem Kubota parts.
Let me add to what I said by saying, if you're putting injector cleaner in your engine mix it with about 20% clean diesel and put it the mixture directly in the fuel filter! I use a 1 liter Pepsi bottle to do this. That way the stronger mixture will get right to the injectors and do its job. Otherwise it might take hours if you put the cleaner in the fuel tank. But put some in the tank too.
A 553 I bought earlier this year did the same thing and when we yanked out the fuel like (a rubber HOSE!!) you couldn't even blow through the hose, it was so collapsed inside! REPLACE THAT STUPID FUEL HOSE WITH SOME STEEL BRAKE LINE. The people at Bobcat should be hung for using rubber hose for a fuel line. That's why so many of them catch on fire. Besides - since when is rubber hose cheaper than brake line tubing?
