I know that this type question has been asked in the past, but I think my situation is a little different. I borrowed the 743 from my dad. I am not familiar with working on a bobcat or a diesel for that matter. It quit on me after running it for a couple of hours. It acted like it ran out of fuel. I immediately tried to crank it back up to see if I could get to my shop. It hit a lick like it was trying to crank. I figured I ran out of fuel, but I do not think so because I put about 1 gallon in before I started. I added fuel and it still would not crank. So today I replaced the fuel filter assuming it was clogged. I has to use an air hose to put pressure in the tank to get fuel to the filter. The primer bulb has been removed sometime in the past. Got it bleeding out the top. I have a downloaded manual I got off ebay (I guess it is good). It said to turn open a valve where the fuel attaches to the fuel rail on the left side of the engine. Then turn over until it cranks and close the valve. Well, that did not work (I am not sure what this valve does or if I have messed up by adjusting it). I then loosened the front injector and tried to bleed it. Turned it over many times and no fuel. So I then loosed the second injector. Turned it over and fuel spewed out of the second injector line. I tightened it back up and waited on fuel to come out of the first injector. After turning the engine over many times… nothing. Ok, here is the question, how do I have fuel to one injector and not the other? I mean the fuel lines do not split far from the injectors. Is there a mechanical control that could be stuck? Could the fuel line itself be clogged (how would something that big get past the filter?)? Also would one injector keep it from even trying to crank? I have not tried to bleed the others yet. Thanks for any help.
