Seems odd....gonna check whether its the same pressure.. but my mechanics told me that the flow wouldn't budge because of the other line. it should be less. nut unless i have a bad control valve. or my charge pressure is high
I can't see your charge pressure being an issue for this, as if it was high enough to prevent the oil returning to the other coupling you would blow your seals in the pump, blow the hydraulic filter off and potentially split your oil cooler.
Your charge pressure should be around 100PSI
If the oil isn't returning, its almost as if something is blocking its return path to the control block. I can't see the spool causing this, its one piece and the ports it slides back and forth in are pretty large and would take something substantial to block up. Does it lock into detent? i'm only curious because if the spool was actually broken inside the control block, it would not disengage. It should pull to the right and POP into place and hold there. You need to pull it to the left to get it to pop back out.
I can't believe how many bugs you have had to deal with in this machine! But i must admit, you are doing an amazing job of sorting them all out!!! and quickly. A 743 i had with masses of problems took me about 12 months to get all sorted out, that included painting too.
