732 Hydraulic mystery problem
I do have the schematics, I was able to pull off of bobcat online parts. When I said return line, I misspoke, meant case drain. in tracing everything out, I can see it does not return directly to the reservoir but does get back there in a roundabout way. I have run the machine with the case drain lines removed, and no oil comes out from them when the motors have a load on them. oil does come out of the motor itself where the case drain line fitting was removed. as I see it the check valve/poppet (located in the block which both case drain lines connect to) should allow oil to flow away from the motor, so using compressed air would force the poppet open and it work its way through the cooler, filter, and back to the connection block that sits on top of the vane pump, which appears to interconnect with the reservoir tank then bubbling up through the tank. I can only think that for some reason maybe the check valve/poppet is taking a lot more pressure to open than it should. that will come apart for inspection next.
I wasted another half a day on the colossal waste of time and money: I was able to map the flow from the case drains back to the reservoir. There is a poppet in the block that both case drain lines connect to. I was able to determine that the pressure required to open the poppet is approximately 20 psi. the connection block was clean and free from any obstruction. I then measured how much pressure was required to force air back through the case drain/return at the motor, which was just a little over 20 psi. However, when I monitor the pressure in the case drain/return circuit, it quickly reaches 100 psi or over when I put a load on either wheel motor. I was able to test them individually by venting the case drain to an empty jug on one while testing pressure on the case drain on the other. There doesn't seem to be any difference from one side to the other, so it seems the motor with the new geroler is behaving similar to the other, so at this point, i guess either both wheel motors are good or both are bad, although I guess I find it hard to believe that both are bad, considering that one had all new guts inside it. so, there does not appear to be any great restriction in the case drain/return circuit. takes a little over 20 psi to establish flow back to the reservoir. things I know at this point: the seal between the wheel motor and the chain case is only rated at 10 psi unable to find information on what psi the bobcat OEM seal is rated at. there is at least 100 psi on the drain circuit when under load Without any spec to go on, and no one else seems to have any idea what else to try(including a bobcat mechanic) and have no desire to waste any more time and or money, I think I am going to try to sell it as a basket case. too bad, cause it really runs well and I have stuck a stupid amount of money, parts, and labor into it over the last couple of years and haven't gotten more than a couple of hours of use out of it. I hate to say it, but I think it is time to give up.
Look up my profile, send me an email, i get more time on email than the forum, see if we can talk it out and get this fixed up. I'd like to think it can't be too nasty, the 73x and 74x machines really were very good
I gave up and sold it.
