643 with bad creeping
wademaniac
My 643 has had a bad creep sence I bought it.Now the control levers are shaking so bad you can hardly hold onto them.I think it is more than just an ajustment.It sounds like the drive chains are lose.Is there anyone out there that has had this problem?Thanks.Please e-mail me at [email protected]
If the chains are loose you won't feel it through the control levers unless you have the park brake engaged, then you surly will feel it as the hydrostatic pumps and motors are fighting against the brake.
It doesn't take much adjustment to have a bad creep.
If you hold the lever for that side in the correct posistion does it feel ok? Have you got the revs up? if the revs are low, you will feel quite a bit of vibration through the levers.
