My 642 was running fine. Then would only run with the choke out. Now it does not start at all. It turns over and will start with starter fluid, but will not run on its own. I have replaced the fuel pickup line in the tank, and the vent is clear. The filter is new, and the solinoid is opening. Pulled the outflow line off the fuel pump and it is working. So It looks like i have to pull the carb and clean it huh? I have the Ford motor, Do you need to pull the manifold off to get the carb off? or pull the entire engine? How the heck that manifold come off? Is it even the carb thats is the problem?
