dylschmidt
- Joined
- Dec 11, 2017
- Messages
- 4
I have an early 642. I have hyra oil leaking into the chain case...It leaks even if the machine is sitting with out running! after 2 days or so it will go down a quart or so.. The drive motors seems to operate just fine..both sides seem equal...I have owned this machine for 17 years (home owner use and clean snow). it operates fine..is it possible the drive motors seals are bad? could they leak even if not running? I have replaced the final drive chains a couple times thro the years, do the chains need to come off then pull the motors out? could it be anything else? Thanks for your help. Darryl
