60XT
There must be a button to release the valve, and you can lift the arms with some lifting macshine. The other option is to unscrew the hoses from the cylinders and to lift it with a some machine .Will run a lot of oil. Do not forget to fix it so it does not fall while you work.
Thanks Walio. Case does a good job of hiding the release for that valve, and also keeping support info off the internet. Uncoupling the hoses worked like a champ.
