540
north farm
Has anyone changed a kohler k583 to an onan p224, I recently purchased a 540 that has an onan in it. the problem i am having is a bad vibrration. it does not have the original connector between the motor and rear pump. someone installed gears and a double roller chain and that seems to be the cause. does anyone have a different method to make this work. i would appreciate your help.
If the shafts line up you could use a lovejoy coupler they have rubber in between the metal halves northern hydralics sells them in many diffrent sizes
Thanks for the response, I will try and find one.
They are actually 3 pieces two metal couplers and a rubber insert between them as long as you get the same coupler size on the rubber side "inside" they can have diffrent shaft sizes on the "outside" check them out here http://www.northerntool.com/webapp/wcs/stores/servlet/NTESearch?storeId=6970&N=0&Ntk=All&Ntt=lovejoy&Nty=1&D=lovejoy&Ntx=mode+matchallpartial&Dx=mode+matchallpartial
