463 won't start when hot
Kent Gorrell
If I let it cool down for 15 minutes it will restart. I've replaced the Fuel Shutoff solenoid and relay but that didn't help. The warning light comes on when I first start but I can't find anything to tell me what that means and I'm not sure it's relevant.
I should have worded it better, what does the light monitor?? coolant temp,oil pressure,alternator voltage?? we need a hint here to help you out.
I don't know, as I said I can't find anything to tell me exactly what it means.
The warning light comes on immediately when starting so its not temperature which is why I don't believe it is related to the not starting when hot issue.
according to the service manual:
Warning lights: Engine Oil Pressure & Temperature, Hyd. Oil Temp. & Pressure.
logically it may be suggestive of low pressure if it comes on straight away and stays on.
but I've checked all those levels and replaced all the filters so I've really no idea.
The main issue is not starting when hot. Any ideas as to why that might happen?
I'm not familiar with that machine but could it be a bad temperature sensor?
From what I can remember there are two lights on the left panel. The top light is for the engine and the bottom is for the hydraulics.
I just can't remember if they are oil pressure or temperature. Not sure if that machine has a safety shutdown for temperature and or pressure or not. The parts catalog does show a hydraulic temperature switch though.
So it starts and runs when cold? It gets hot and shuts off? Is that it?
This is the diesel eng. Correct ? I noticed it may come with an air cooled eng but smaller. That said if it is the diesel and starts cold. Warms and then will not restart. Then I would look for an overheat control switch if it has any. It sounds like it does. Based on you comments. Why is it overheating? Radiator plugged? all that good stuff. Good Luck! Report the find that fixes it. Thanks
Sounds like the temperature switch. To check this take the wire OFF the temperature switch. We had even put a new NAPA numbers matching switch on it and it wasn't working correctly. We had to get a switch from the stump grinding equipment mfgr. I thought the engine mfgr. would have most input, but no.
There is a hydraulic oil Temperature sender / switch. The manual is a bit ambiguous as to whether it is a sender or a switch. in one place it is called a temperature sending switch, in other places called either a sender or switch. Is this a sensor/sender that would cause the warning light? if so, should I disconnect it to see if the warning light changes?
Would this be causing the issue of not being able to restart when hot?
Try it. Can't hurt to find out. That could be one issue if the Hyd. system gets way hot and pressure builds it may be a safety switch.
