453 coolant drain cock location D750
Mrmike
Hi can anybody help with info on location on my drain valve , I've raised the cab and look all over thanks Mike
On my 453 with the D722 you barely see it on the back side of the engine. It's near the middle of the block and has a small barbed fitting pointing down. If there's no tubing attached slip a piece of 1/4” tubing on the fitting long enough to go around and out the rear door before opening the valve.
Thanks for your great info , I located the same valve type on my machine , but the tap handle is gone likely was snapped off by last owner , I was able to remove a gallon of coolant out with my wet dry shop vac and able to refresh the coolant Mike
