This has a Izuzu engine and it is hard starting. by this I mean that it turns over very slow. Have installed 2 new rebuilt starters,new battery ,new bat. cables. If I hook bat.charger to bat. then it iwill turn faster and eventually will start.. The new bat. is the same size as the one removed{550 cca}.The original starter worked good other than for the drive teeth being clear gone from wear, or???? I am wondering if someone has wire diagram that goes to starter-solonoid. Thanks
