323D - Prevent from starting
klaatu
Is there a simple means to prevent the engine from starting when cranking?
This is on a 2013 JD 323D
Trying to avoid messing with the fuel delivery... BUt there may be a simple fuel solenoid that I could disconnect. Any such thing?
you could remove the glow plugs if equiped. and yes most likely there is a fuse that could be pulled killing the fuel system.
if you pull the glow plug fuse/relay it is possible it can still start . I wrote to remove the glow plugs. The fuse part is for the fuel shut off and possibly fuel pump.
