I need to remove the spool valves to replace the leaking spool valve Orings and seals. the tilt and lift are both leaking from the back. I've removed the front linkage, front hold down plates and block with the solenoid locks but there does not seem to be enough room behind the valve control body tor pull the spools out. the fuel fill hose and the tank vent hose are blocking the way. The hose clamp on the bottom of the fill hose is backwards and I cannot reach it from the back to remove the hose. It is impossible to move the hose to the side due to main supply hose to the hydraulic pump. Any one with any experience with this? I could remove the main supply hose and try to move the fuel supply hose and the vent hose to the side to create more clearance but the valves are 12" long and the distance between the valve body and hydraulic pump looks to be about 12". the bottom spool with the cap and ball/springs looks to be about 14" long. my unit does not have auto level, or at least it has never worked since I've had it. I've had it for 20 years. Do I need to remove the hydraulic control valve in this model to remove the spool valves? Has anyone had to do this before???
