Well,here's an update on my 773 G-series loader. It's in my shop nice and warm which makes it a lot easier to work on! Wanting to totally eliminate the possibility of a wiring,connection,ground,harness,fuse,relay,solenoid,contoller,panel,ignition switch,or related electrical/electronic problem I painstakingly followed the wiring harness in it's entirety checking for all of the above. I even went as far as removing,grinding,cleaning and resetting in place all known chassis,cab,engine,battery and electronics grounding points. I inspected the wiring harness and plugs/connections exhaustingly for indications of rubbing,shorting out,corroding,moisture,oiling even going as far as to spray (even though all were in pristeen condition) the connectors with a top line electrical/electronic connection spray. I also removed the bics controller,the left and right side overhead panel modules and removed their covers (carefully) to inspect the circuit boards for visual overheating and/or "sparkouts" which is the only test on these modules that a layman can perform. Any of them could be bad even though they look fantastic,as I know! I am about at the end of doing what I know to do as far as isolating this problem. I realize (but dread) the thought of it being a controller/bics problem because of the money and or availability problems associated with them but it looks more and more like it points to that. (I even checked the air in the tires-three times,LOL !) So any other suggestions would be helpful,guys! C'mon put your heads together!! No suggestion could ever be considered too simple or lame as I,although not a smart man, recognize the value of even the most basic and simple of suggestions ! You never know! I think I will try to clean the rear window,inside and out and see if that works! lol. Thanks again! Jim
