Hi all; I'm new to this forum and have enjoyed past posts,etc.,and now I need help! I have a 1999 BC 773 with a Kub v-2203 engine,about 1300 hours on it. It sat outside for about a month in the cold (Ohio) weather. Went to start it and Batt was dead. Removed batt,charged and put back in few days later. Started right up as normal. After un-freezing from the ground,I put bc inside heated bldg to thaw out frozen components such as throttle cable,etc. few days later I took it outside to push a little snow around. 10 minutes into the operation bc died just suddenly as if fuel supply was cut off instantly. Re-started it and it happened again after a minute,then re-started and same thing again. Got out to re-check battery and sure enough the positive terminal was so loose it just lifted right off of the post. That (I thought) explained the sudden die-out when restarting and attempting to move it. So, I removed,cleaned and re-tightened both terminals and confirmed that the battery is fully charged and tried to start it. This time,however as soon as I turned the ign key to the "on" position,all lights and indicators on the overhead electronic panels,as well as the beeper alarm sounded and blinked every second and will not stop even when removing the ign key ! The "hours" readout display also flashes with all of the numbers flashing 888888's. I went over everything today again including all of the grounding points from the negative side and all of the positive connections. I literally removed and cleaned where necessary all contact areas,(which were pretty clean and corrosion free anyway). I also checked the 100amp fuse that is the first stop on the positive side from the battery and it was fine (continuity check). So I need help!!This thing quit on me in the middle of my driveway. If anyone can suggest something else,I'm all ears and would really appreciate it. Thanks much.
