1996 Mustang 940E Hours
Odyknuck
Is 4700 hours a lot for this model machine. It is in decent shape with new foam filled tires for $6000.00
I would say no. Not sure about the e series, but he 940,960's were pretty much bullet proof. We had a960 with 8500hrs and had done very little except regular maintenance to it. I have to admit that I am biased to mustangs. We have owned 5 different ones over the years and they just seem to run. Our 930a was probably the most troublesome with axle bearings. Not sure about price that seems like plenty for a 15yr. old machine?? Check it over good.
Agreed. I think the price is a little steep. I paid that for my 2000 2040 with less than 1,000 hrs. I think there comes a point where the hours don't really matter, just if you can get parts anymore.
Sure would like to find some of those deals . It would seem the prices are higher in the Ohio . I am looking at another 940e with 3000 hours that comes with a smoth and toothed bucket, snowplow and chains, cab enclosure and the auto tilt arms and bucket option. He wants 6000.00 for that.
Forgot to add it needs tires
Tires are cheap and not a deal-breaker. I just re-booted mine. $534.00 including tax & mounting.
Well I found a 1996 940e with 3000 hours on it that comes with a smooth edge and toothed bucket, 7' Myers hydraulic plow, wheel chains and cab enclousure for $5800.00. Needs tires and the heater fan is not working. Both simple fixes. I pick it up this friday. Anybody know if 12" wide tires will fit on this machine. The stock ones are 10".
Don't know for sure if the 12" wheels & tires will fit. Depends on lug bolt size and circle, pilot circle, distance between tires, depth of wheel to chain case (reverse wheels maybe?), tire to frame vertical clearance.
I was just going to change the tires out to the 12" I realize the rim withe may be different however it may not make that myuch difference. I can pick up a set of 4 used 12" tires with about 90% tread for $275.00
