1985 L785 starting help/service manual help
Erik6693
Hello, I just picked up a 1985 L785 and it started no problem two days ago. I sat in it today fueled it up and now nothing no light, no power, no nothing. I put a new battery in it and still nothing. Not even the seat belt light which normally comes on. Is there a fuse box/panel somewhere on it.. Or does anybody have a parts/service manual they maybe able to email me? Any help would be greatly appreciated! This is my first machine, so any help would be great! It's as if it has no power.. Thank you
There are not fuses in the system, but it does have circuit breakers. They are either on the right side or left side in the engine compartment. Flip the hood open and at the front of the opening look on the side walls for them. The wiring diagram is in the parts book. You can go to Newholland.com to access the parts books.
I will check thanks so much for the info. I am leaving for vacation for the next week, but I will check back and let you know.
Thanks again for the info. The culprit was a bad ground off the battery to the chassis. I ended up putting a new battery in which it needed anyways, it wouldn't kick over and I have an auxiliary fuel pump on it and it wasn't running, I happened to move the ground and it kicked on. But not enough start it, I ended up using a jumper cable from the battery to the chassis and it fired right up. So I'll be replacing the ground.
