1845C Loader Arm Bushings
Scavenger
Is there anyone here who has some measurements for the bushings at the end of the bucket arms where the quick attach plate is fastened. I would need the I.D, O.D., and the length. Also the pin diameter and length would be appreciated. I tried looking up the bushings at the Case Parts page, and all they give is a part number (D33827) and measurements of 32mm (1-1/4"). I bought the 1992 1845C used and believe the previous owner made his own bushings and pins because something just does not seem right, and it is very obvious that someone with very low welding ability welded in the present bushings. I have a relative who has a tool and die shop who is willing to make me a few sets if I can supply him with the correct measurements...........thanks.
I was unable to figure out how to edit my above post. I was going to ask for the pin part number also. In looking at the Case parts site, it is listed somewhere under "Case Coupler" but they have several to choose from. I need the pin that has a metal tab welded to it. A bolt is then used to fasten the tab in the proper position..............thanks
They should be very simple to make. They should be a standard size too. Can you remove the old ones and measure the holes and get them machined to suit?
