alchemysa
- Mar 29, 2016
- 203
Upon removing the round side cover of my recently purchased 610 'project' I discovered I have no variable speed mechanism. The hose from the control valve had been removed and the valve outlet was plugged. And as you can see the roto-swivel assembly is entirely missing.
A spacer (a small piece of pipe offcut) had been slipped onto the plunger to prevent the plunger from retracting too far. (See the pic with the red arrow). This, combined with a well worn belt meant the machine was permanently in low speed mode. I guess if you weren't in a hurry it would have worked OK.
I want to restore variable speed so I guess I need a few parts. The parts marked in red on the diagram are all missing. Does anyone know whats in a roto-swivel kit? I tried looking at the Bobcat parts website but I cant make sense of it. It keeps saying the pages are 'unauthorised'.
http://www.bobcatpartsonline.com/bobcat/mainPage.jsp?home=yes
A snip from my own parts catalogue is shown below. I'm a bit confused about the parts marked in blue. If you look at my photo of the inside of the plunger you can see 2 small pins. The diagram gives the impression there are more parts 'under' these pins but I cant see a snap ring or anything that needs to be removed. Does anyone know if theres more disassembly to go?
Also any advice on where to get parts would be appreciated. I suspect parts here in Australia will be exorbitant so I will perhaps be buying from the U.S. I have a friend in North Carolina who will forward anything to me that I get sent to him.
Any comments on this situation are welcome.
