T190 coolant warning light
Gmh
have a T190 , the coolant warning keeps coming on , but we have water/coolant , its not low , the machine then looses power ?
brdgbldr
Sounds like you may have a bad sensor, wire to the sensor, a bad pump or bad thermostat. Make sure if the machine is overheating or not. This will narrow it down.
The computer is shutting the machine down because it senses there is a problem.
G
Gmh
Thanks will check those out
