853 Coolant Leak - Can't Find it!
Rambler
A couple weeks ago I removed the engine and Hydraulic pump to replace the seal on the pump shaft and had no leaks when I reinstalled it. This week when I start the engine after a couple minutes I get coolant dripping from the two metal cutout holes located underneath the skidsteer. I have checked the two hoses coming off the Radiator and the Radiator and there are no leaks. I checked the water pump and thermostat housing and there are no leaks. I checked the overflow Bottle and hose and there are no leaks. The sides of the engine and the plastic area underneath the engine and the Hydraulic pump are bone dry. What could I be missing? Thank you
