Ok so I have a leaky outer hub seal on my t180. I noticed it after sitting for about 2 months. It ran straight down the inside of the sprocket, so it must have started while it was sitting. I am fairly mechanically inclined as I have built several vehicles, and do all of my own mechanic work; however, I have never torn into any final drives so I'm a little hesitant as to what I may be getting myself into. Is it a difficult task to pull the final apart and change the outer hub seal? Is there other seals, o-rings, bearings etc. that I should replace while I'm in there? Do I need any special tools? Any advice is much appreciated. Also, am I going to be in over my head on this project, or is it something that someone like myself can handle? I should also mention that I changed final oil sometime last summer, along with a major system maintenance overhaul including the case-drains, all of which looked clean and in working order. I even cut the main hydro filter to ensure no major particulate was flowing though the system. So I do not believe that it is excess pressure pushing from a failing drive motor. Thanks fellas!
