7753 engine oil leak
John Klink
I have a 7753 75% of the oil leaked out or blew out. It seems like the leak is on the back side of the engine, or up by the blower. I cant see anything other than where the oil flows to the bottom of the engine. I added oil and let it run for 20 minutes and last no oil. I then revved it up for about 3 minutes and it started to leak? Where should I start to look? I don't have any tech manuals and cant see anything. Id like to know more about it before I have to take it into the dealer. especially if I can fix it myself.
antfarmer2
First don't run it with out oil I can't see it from here but would look at the oil pressure sending unit
J
John Klink
Thanks, I cant see it from anywhere I look on the engine and haven't taken anything off yet. I filled it up with oil before I ran it. I will check the oil pressure unit. Thanks John
J
John Klink
I belive your engine is a kubota 2203
Thanks for your help. I Lifted the cage up one more time to see if I could see more. I put a roller cart over the actuator arms and got as far back as I could. As you know visibility is pretty poor on the back side. I reached for the blow over hose to see if it was connected, and then saw that there was a hole in the engine, which ended being a dipstick hole on the lower backside of the engine almost completely unseen unless you crawl and cram your head back as far as you can go. Bottom line it was a dipstick for the oil pan that blew out. When I went to high RPM's it blew the oil out.
antfarmer2
Glad you found it while your in there see if your blow by hose is plugged up
The dip stick should never just blow out.
Not sure if these machines have breether tubes or not, if so, wasps like making nests in them.
If it doesn't have one open to the atmosphere, check the line from the rocker cover that may go to the inlet manifold.
7LBSSMALLIE
seen this about a dozen times, its a plastic plug . kinda dumb if you ask me. never had a repeat after replacement. i use a little permatex #1 on it
