Chain oil leak S250
fjsuhr
I have a S250 bobcat skid steer and it started leaking from the bottom right area under the body. Is there some type of plug that fell out? Assuming it's gear chain oil…
brdgbldr
There are drain holes, 2 in front and 2 in back, that are on either side of the actual chain case to let fluids and debris come out From around the hydraulic components. There is also an access panel that is just behind and in between the 2 drain holes in the back.
You need to raise the cab and check for hydraulic leaks. It could be blown seals or hoses.
It is probably not from the chain case unless the chain case is overfilled and coming out of the access panels on top of the chain case. (This would be an indication that your motor carrier seals are leaking.)
The access panel is to get to the chain case and fuel tank drain plugs. These also can leak, but rarely.
