warrenoliver
- Joined
- Jan 10, 2009
- Messages
- 8
This thing is kicking my butt. Original problem was fuel issues once I changed the glow plugs and put it all back together. After bleeding the fuel lines, I had trouble starting and once running, it had very little power. I used an IR thermometer to determine one of the cylinders were not firing. I found a loose connection on the fitting at the fuel pump which allowed diesel to seep out of the fitting instead of opening the injector. Once I tightened it up, she runs much better. The problem I am having now is that it is still hard to start when cold and I am getting fuel leakage on top of the pump around the injector fittings. I can't see which fitting is leaking. I am going to take the fittings off again and tighten each one again. What is the trick to getting these to seal right? I tried to make sure the fuel line is aligned correctly and seated before tightening the flare nut. I am afraid to crank too hard on the flare nuts thinking I may damage something. What is the trick here? Thanks in advance for your help.
