General Discussion Forums
Introduce Yourself
Yet another Canadian
Reply to thread
Message
<blockquote data-quote="gatechalky" data-source="post: 38319" data-attributes="member: 4569"><p>I just purchased a very used Bobcat that I don't know the exact model but I believe it may be an M444. It has a two cylinder motor. It has 4 (7 X 15) and is two wheel drive. It has a gasoline engine with two tanks. It does not have a key start (has a switch for turning fuel pump on and off and push button starter). There are two gauges on the panel by the switch and starter (pressure and ammeter) It has the Bobcat name and emblem on the arm. There are two floor controls with a separate control for unknown on the left side wall behind the left pedal. It has a roll cage that appears to have been added by a previous owner. It is air cooled and has a large hole on either side behind the rear tire. Does this appear to be an M444. I bought the service manual for the M444, M500 etc but it does not show any pictures of the different models. Thanks for any help you may provide. Alan Bundy</p></blockquote><p></p>
[QUOTE="gatechalky, post: 38319, member: 4569"] I just purchased a very used Bobcat that I don't know the exact model but I believe it may be an M444. It has a two cylinder motor. It has 4 (7 X 15) and is two wheel drive. It has a gasoline engine with two tanks. It does not have a key start (has a switch for turning fuel pump on and off and push button starter). There are two gauges on the panel by the switch and starter (pressure and ammeter) It has the Bobcat name and emblem on the arm. There are two floor controls with a separate control for unknown on the left side wall behind the left pedal. It has a roll cage that appears to have been added by a previous owner. It is air cooled and has a large hole on either side behind the rear tire. Does this appear to be an M444. I bought the service manual for the M444, M500 etc but it does not show any pictures of the different models. Thanks for any help you may provide. Alan Bundy [/QUOTE]
Verification
Post reply
Introduce Yourself
